"even at steady throttle its all over the place"
AFR gauge will jump back and forth at steady throttle. That shows it is working, as the ECU reads the O2 sensor it adjusts the fuel one way then the other.
It can show if you have a bad MAF or O2 sensor so it is not useless. I use it to test Z32 MAF's, I can spot a bad one is 3 seconds.
_________________________Jeff Hhttp://
www.heavythrottle.com
