sr20det hicas pump on ka24de?
diablodude64
Car: 1991 Nissan 240sx SE
Probably been covered already.... But to make things simple! Are the two powersteering pumps the same but different pulley? If I bought a sr20det hicas pump, would my ka hicas pump's pulley fit? Thanks, Kyle
sean@z1
Car: 1993 240sx
Dose the mounting points look the same? If so then yes if not then NOT with out modification.
Hijacker
Car: '92 240sx Convertible
'94 F-150
IIRC, the KA and the SR pumps differ in the way they apply tension to the belt. I know I've seen modified KA pumps on SRs before, I just forget exactly what needs to be done to make it work.
White Comet
Car: fc, s13 and mazda6, Sierra
Hijacker wrote:IIRC, the KA and the SR pumps differ in the way they apply tension to the belt. I know I've seen modified KA pumps on SRs before, I just forget exactly what needs to be done to make it work.
hmm never heard that before. i'm running a ka pump (non hicas) on my sr. you just have to reuse the sr brackets
