SR20DET helpp
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
Jsilvia116
Anyone has an idea of how to fix speed sensor or the wiring??
My Sr20det has a little problem that.....i think its either the voltage n vacum leak
When i start up the car, i have the rev it a lil pass 1500rpm so the dashboard light.....will be brighter as usual also when i warm up the car.....the rpm drops 700rpm or a lil bit below.....seems like battery's low but i changed it recently.... PS: i have the small battery
but if i drive the car for awhile than none of these problems will occur....does anyone have an idea??
nametakennow
Car: '06 MINI Cooper S
Judging by your username, this is in a 240SX, right? If so, wrong section. This is FWD SR.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
