dan222000 »
https://forums.nicoclub.com/dan222000-u59798.html
Tue Mar 17, 2009 1:05 pm
ok I went to start my S14 the other day and it started up fine, then it started to run like it was on 3 cyclinders and died. I started it back up and it was running on 3 cyclinders. First I checked the injectors and found that one was not working. So next I pulled the coilpack and checked it for spark. It had plenty of spark. So then I pulled the plug and check it for spark. The plug had spark. So then I got multimeter and check the wires to the injector and I got no reading. Does anyone know what this could be? ECU? Lose wire? Any help would be great.
Thanks,Dan
