SR20DET HElP loud clicking noise
JAG_S13
Car: 1990 s13 sr20det
so the other day i was driving and the hose going from the valve cover melted from being to close to headers....anyways i took the car home replaced the hose started it and this obnoxious loud clicking noise was there. when i rev up the clicking gets faster, and it seems like it sputters and dont raise rpms fastt. anyone know what it could be? im thinking valves, maybe timing chain? no idea im 17 and dont have much experience. Any ideas of the problem would be appreciated. thanks http://mail.aol.com/33069-111/aol-6/en- ... G_0547.3gp
zachattack_5491
Car: Pignose S13 Redtop SR
Could be knocking. You should test the compression. I don't know if that was supposed to be a link to the sound or what, but it doesn't work.
240sxRturbo
Car: 1991 240sx lx 10:1 compresion
im not 100 percent sure on the sr motor but if u have a big enough vac leak it will cause a loss of oil pressure and make ur timing chain loud just experianced it first hand good luck :)
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
If it is bottom end pull the. Plug to each coil one at a time and see if the noise changes or goes away. If it does change its bottom end. I'm betting with the way its running you have a collapsed lifter not allowing valves to open enough. A compression test should. Tell you which cylinder is affected......maybe solid lifter time?
Takumi788
Car: 1992 240sx Vert - sold
1990 240sx Hatch - sold
compactfean is right. SR's have hydraulic lifters that tend to just randomly drop when they get old. Nothing to serious. Park it, replace all of them (not just the collapsed one), call it a day.
http://www.frsport.com/Genuine-OEM-Niss ... _8061.html
- These guys will beat any price - $49 per lifter is the best i found.
JAG_S13
alright im going to put a vid up here soon i know the last one didnt work. but yeah that makes sense what yall are saying. i took the valve cover off and the timing chain seems fine. ill check out what yall are talking about though and update yall. preciate the help.
