You only have 10 links not 11. Rotate the exhaust cam clockwise and jump the chain another link to have the 11 links including the 10 and 12 dots.mdgeist wrote:Ok, here are some pictures on where I' am at with the timing.
The timing chain tensioner is not installed yet.The silver link is on the intake side correctly lined up with the dot. Plus the long screw driver is touching piston #1 at TDC.
But my problem is that the exhaust camshaft is not at the 12 o'clock position and the chain link count from intake to exhaust marks are only 9 links.
Pulley on second notch showing that piston #1 is at TDC.
Lobo240sx wrote:Make sure before you do this to remove the darn ratchet from the crank. I had a friend that ended up digging a 3 inch hole in the ground with a destroyed 1/2 drive ratchet lol.
