sr20det head gasket
silk240
Car: '92 white 240sx coupe w/ blacktop sr20det
can i run a 86mm x 0.8mm thickness head gasket with no problems what so ever and with out doing anything to the valve train?
silk240
anyone?
rc1honda
Car: 1992 240 sx
2007 BMW 335xi
2008 Honda CBR1000RR
Yeah that should be fine if you have stock bore pistons. Also you can always get a bigger bore gasket and it will work fine, but you cannot get a smaller bore gasket then the piston bore. The 86mm is actually 87, It will work fine. Also remember when your are installing to spray the copper gasket sealer on it. Spray a thin layer of that copper stuff on both side of the gasket. Also the gasket thinkness is fine. Stock i think is .5mm you are going a little thick which will slightly lower compression, which in tirn will let you run more boost safer.
silk240
thanks man, so if Apexi is offering a 87mm bore also should i get that instead? i am running stock bore.
Modified by silk240 at 6:52 PM 5/19/2009
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
actually 1.1 is stock thickness. ,8 will up your compression slightly but not enoguh to really notice
