Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri Mar 07, 2008 10:55 am
Unless you hate life and happen to have a complete and total understanding of how the harnesses are put together, you'd do yourself, and your life span, a favour to steer clear of doing that job.
The S14 and S13 harnesses are not compatable. you could conceivably splice the harnesses together with the S13 plugs and a lot of soldering/rerouting, but unless you happen to be a master auto electrician, it's not a task that would be fun and exciting.
That point aside, the JDM and USDM harnesses are routed differently. The wonderful and "fun" Super Multi-Junction plug is always on the driver's side of the car. It is the linking point for the interior main harness to hook up with the engine bay main harness. So you can imagine how many power wires, signal wires, and test wires go through that. You would have to lengthen and solder more wires than you'd care to count.
