Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Thu Jan 10, 2008 5:52 am
First off, welcome to NICO! I'm glad to see you very enthusiastic about this build. I've seen people crop up asking a few questions in the past, but they never really reported if they accomplished their goals or not.
I don't have any how to's or parts guides specifically for doing hardbody swaps, but aside from the mounts and power steering, it should be pretty simple.
I can't think of anyone off hand that makes custom mounts, but I'm sure someone on the boards knows if someone has mounts or not. If not, fabbing up custom mounts isn't too terribly hard for someone with good welding skills and a good eye for modding brackets.
The wiring will be pretty straigtforward I think. I don't have a wiring diagram for a hardbody, but the EFI harness is pretty self contained. The main wires to be concerned with exiting the harness are the speedo wire, the incoming power wires for the ECU and ignitor as well as the signal wire going out to the fuel pump relay.
I'm not sure if the steering will be a problem for a hardbody. It's a tight fit in a 240 for the steering column and turbo. The column may be present a big obstacle to overcome.
