Sr20det hard to start and wont idle! Plz help!
projsilvia
Car: 95 240sx base model w/ s13 redtop
So when i try to start my car with the fresh sr20 swap in I have to hold the throttle almost wide open. Then when it does start the idle oscillates. ive adjusted the iacv both ways and it doesnt seem to help the problem at all. Also ive been lookin for possible vaccum leaks. Im thinkin its the TPS causing the erratic idle. But as far as not starting w/o holding the throttle open im out of ideas. fuel pressure is at 46 with the stock sr fpr. Anyone know if it could be caused by plug gap or possibly not enough fuel delivery when cranking? I havent installed my 255lph pump yet but ill do that tonight or tomorrow and see what happens. Any help would be greatly appreciated. Thanks, Dustin
projsilvia
So after alot of work ive got the car running strong at 13lbs of boost. I had alot of boost leaks, my timing was all crazy because the CAS was off a tooth, and i had my PCV capped off for some reason (Probably because i was drunk trying to plug vaccum leaks.)
projsilvia
Sorry for what im about to do i hope it doesnt get me in trouble. I need to be able to post in the classifieds so im gonna bump my way to 10 posts in my own thread. Again please mods if this is a problem let me know before banning me or something.
projsilvia
bump
projsilvia
sorry =(
projsilvia
only a couple more =(
projsilvia
I'll try to get some pics of the ride to post and more info. I'll bring it to the next nopi event in phx
projsilvia
bump
projsilvia
=) 2 more
projsilvia
Last one. Sorry again
