I figured I would pop this right here, So you guys could see it!
If you have any questions AT ALL about the haltech, hit me up on AIM or give me a ring!
--John
Haltech E8 Plug and Play Kit On Sale!Discounted $150! Plug and Play Kit for $1325!
We are kicking off the new year right! You get the powerful Haltech E8 ecu, suited perfectly for a 4 cylinder application with Full Sequential ignition and injection.
Get rid of the maf, and all that extra piping! The haltech E8 Kit converts your setup to a MAP sensor, clearing up engine bay clutter, and maximizing pressure based tuning, open atmosphere bovs, your turbo will never be too big for your AFM again!
The typical Nissan Ecu Only uses two ground drivers for fuel injection, meaning it fires two sets of injectors at a time. This leads to poor idle when upgrading injectors. The haltech E8 Utilizes 4 Separate Ground drivers (one per cylinder) to maximize minimum injector times, and give GREAT idle quality.
This kit is perfect for the Stock to fully upgraded ecu. Since the ECU is unlocked, you can easily modify it as you add modifications to your car.
In this Kit you get:Haltech E8 ECUPlug and Play Harness for the S13 CA18DET, SR20DET S13, S14, S15 or GTiR N14Data CableInstall CD with Manuals3 Bar Map sensorAir Temperature Sensor
E8 ECU Spec Sheet
PLUS! RPSports Personal tech support! We are an Authorized Haltech Dealer, well versed in the Haltech ECU.
PLUS! Our Own complimentary base map. We NEW maps for the S13, S14 and S15 in stock configurations that run perfectly. We can also make adjustments on your first map to match larger injectors.
Add a boost controller! its only $88 bucks more!
Need a wideband? The haltech Wideband will synch with your ecu giving you Lambda datalogging over your runs. Synch it to closed loop, set your ecu and go! Only $200 more!
Get in touch! Pay via PayPal Verified!
AIM: RPSportJohnEmail:
[email protected]: 562.489.5016
