SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Wed Sep 17, 2003 9:38 am
NISSAN SILVIA (PS13) ENGINE OVERHAUL GASKET KIT & PART NUMBERS These are Japanese Part Numbers, Not to be used at U.S. Nissan Dealers.
PART NAME: PART CODE KIT # 11011K: KIT # 11042K: Gasket Kit: Engine repair 9101-11011K 1 - Gasket Kit: Valve Re-grind 9101-11042K - 1 Seal: Oil Crankshaft Rear 9101-12279 - 1 Gasket: Drain Plug 9101-11128A 1 - Gasket: Cylinder Head 9101-11044 1 1 Gasket: Chain Tensioner 9101-13070E 1 - Seal: Oil Valve (intake) 9101-13207 8 8 Seal: Oil Valve (exhaust) 9101-13207M 8 8 Gasket: Rocker Cover 9101-13270 1 1 Gasket: Rocker Cover 9101-13270M 1 1 Gasket: Rocker Cover 9101-13270N 4 4 Gasket: Oil Filler Cap 9101-15255A 1 - Seal: Oil Crankshaft Font 9101-13042 1 - Seal: O-rings 9101-13035H 1 - Gasket: Intake Manifold 9101-14035 1 1 Gasket: Collector, Intake 9101-14010A 1 - Gasket: Throttle Chamber 9101-16293 1 - Gasket: Exhaust Manifold 9101-14036M 1 1 Seal O-ring Oil Strainer 9101-15053M 1 - Seal: O-ring Pressure Regulator 9101-16412E 1 - Seal: O-ring Injector, Lower 9101-16412F 4 - Seal: O-ring Injector, Upper 9101-16412G 4 - Seal: O-ring Support, Distributor 9101-22100E 1 1 Gasket: AAC Valve 9101-23785N 1 - Gasket: Turbo Charger, Inlet 9101-14415 1 - Gasket: Turbo Charger Outlet 9101-14445 1 - Gasket: Inlet Tube, Air 9101-14465M 1 - Gasket: Oil Tube, Inlet 9101-15196 2 - Gasket: Oil Tube, Outlet 9101-15196M 1 - Gasket: Connector, Water 9101-15188A 6 - Gasket: Liquid 9101- 1 -
Not sure if that helps.
