sr20det fuel problems
nice_try
Car: '90 240sx with a bone stock sr20 swap!
hey guys i'm the one with the new sr20det....i swapped the fuel lines like ya'll said but its still not workin.....any suggestions???
180fan
Car: 89 fastback
well how about something more to go on rather than "uh, I changed the position of the fuel lines"
for example:well it turns over but doesn't idle. it'll have an oscillating idle and then will sputter out and die- or -when i turn the key, nothing happens. I can hear the fuel pump prime. when i took a fuel pressure gauge to the fuel system, it looked fine, but there was no spark.
and so on. Details.
nice_try
well it turns over but doesn't idle. it'll have an oscillating idle and then will sputter out and die...
ChicagoS14T
Car: 95 240SX SE 5spd
Did you connect everything properly? Does the fuel pump work? Did you check fuses, is the Fuel pressure regular on correctly, etc....
180fan
Car: 89 fastback
you using anything like an AFC that will modify the air flow signal by any chance?
nice_try
everthing is stock....do you think it might be the timing?
