1001% man. 2 important notes though:ks13 wrote:woods crasher thats interesting information.
are you 1000% positive?
You could probably stack a lock washer and a regular washer, and use loctite. As long as its torqued to spec it should suffice.Woods Crasher wrote:
2. Be careful with the flywheel bolts. My stock CA bolts were too long and bottomed out. Thus cause the flywheel to come loose, ruin my baller *** clutch. and ruin all the threads in the back of my crank. So measure and make sure you bolts aren't too long, head over to boltdepot.com and get some shorter grade 10 metric bolts and washers.
Do you have any pics? How much did you grind flywheel/cover? Didn't it decrease strength of cover plate?turbo-sil40 wrote:I am using a toda lightend flywheel and act 6 puck clutch on my car, bottom line is the the sr flywheel and clutch are to big for the ca bell housing and will rib the inside I had to have the outside edge of the clutch and flywheel machined on a brake lathe to make them fit but after that, they fit like a glove I am 99.999999% sure all these sr to ca setups have to be machined bc the sr flywheel has a lip on the outside and the ca doesnt and thats what causes the rubbing, and the clutch is the same size as the flywheel and thats why it has to be machined too. I would advise taking it to a machine shop with experience bc they both have to be perfectly centered so they will stay balanced.
so i decided to ignore work all day today and found this thread...Woods Crasher wrote:
1. They use a smaller t/o bearing(at least my ORC Ogura did) I bought the smaller t/o bearing from Phase2motortrend.com, but I don't see it on their site anymore. If you buy it new you shouldn't have to worry.
Ca_Silvia wrote:810 USD for ORC CA clutch compared to the same price for the SR clutch, however, the SR clutch includes a flywheel.
http://www.nengun.com/orc/409-...400ps
If this is true about this brand and the SR clutch/flywheel combo, this is sweet. These clutches are bad a**.
Hello. I was looking at some of my old posts and found this thread!Ca_Silvia wrote:I am only assuming that the SR clutch users are going with an s13 Red Top clutch. Just a guess really.
Perhaps Woods could chime in on this one?
bimeur wrote:from my known,you have to use sr20det bolts,they're shorter than ca18,and fits bolt-on
Did you actually read the whole thread before posting? It's barely a whole page. He says which one works.Vetal wrote:What are these "baller type" clutch you mentioned, that work with stock S13 starters?
