Sr20det flooding...????
DailyDrivenS14
Car: 1996 Nissan 240sx KA24DET, 2007 Gsxr 1000
If i start the car, drive it, park it, and turn it off, it wont start back up... I can disconnect the fuel line and crank it until it fires off of the gas that is still in the cylinders/fuel rail. When that gas runs out and it dies i can reconnect the fuel line and it will start right up... any suggestions will be greatly helpful!!!
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
bad o-rings
DailyDrivenS14
injector o-rings?
otterman
Yeah I would say bad injector o-rings. Does the car run like **** when it does start?
DailyDrivenS14
runs smooth as a babys butt when i rev' it up, a havent really been ale to drive it too far though because i dont have tags and am running open downpipe since i just got the motor back in. The po-po are all over my street lol. OH YEAH. and this may be just a "side effect" of the open downpipe but it backfires quite a bit on rev-down
DailyDrivenS14
PROBLEM SOLVED! ok just an Fyi in case someone has the same problem, i changed the fuel rail, which included injectors/o-rings, and FPR and it didnt solve the problem but it was worth a try... It turned out to be the coolant temperature sensor on the intake manifold. its right behind and to the right side of the throttlebody! Thanks for the sugestions everyone!
