SR20DET FB RX7 swap
Meifert
Car: 1985 Mazda RX7 SR20DET swapped
2014 F250 FX4 4 inch lift 37 inch tires
I am swapping an SR20DET into my 85 RX7. We are using the entire front suspension from an S14 with 300ZX rotors and calipers. My question is what 16x8 wheels will clear the brakes?
PapaSmurf2k3
Site Admin
It'll be very spoke-dependent.
Also, are you using the 26mm or 30mm brakes?
Meifert
PapaSmurf2k3 wrote:
Tue Apr 24, 2018 6:44 am
30mm brakes.
Meifert
Bump....
PapaSmurf2k3
Site Admin
I mean... Z32 wheels will fit for sure haha.
Just make sure the spokes don't wrap in-board past the mounting flange of the wheel too much and you should be ok. Worst case scenario, you'll have to run a spacer.
