doridori23 »
https://forums.nicoclub.com/doridori23-u68081.html
Wed Jul 04, 2007 11:42 am
It gets so hot the only loktite that would hold up would be Sleeve Retainer (green) and if you put that on your studs they will never ever come out (this being bad).
I had someone put it on his studs and the studs were too long (and since the only way to remove them would be to break them off, drill them out and retap the hole) he had to spend hours with a file making each one shorter and still keep the threads in good shape. Only use blue or red loktite and NEVER use green (Sleeve Retainer). Purple loktite is for hydraulic systems btw.
