SR20det engine swap
240sxkid2
What do i need to swap a sr20det engine into a s13 chasis. what is the process for swapping this engine into this chasis. This is my first engine swap any input would be great!
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
check out the sticky at the top of the technical forum, and in all cases SEARCH!! :dblthumb:
240sxkid2
im looking to see who knows how to wire the harnesses together?
JDizzle
Car: 1995 Nissan 240SX
Wiring will change depending on which SR20DET you're swapping into your S13. If you don't want to do the wiring yourself, wiring specialties makes a direct replacement harness.
