My 240SX S13:
1996 SR20DET Blacktop
Garrett GT2871r .64 turbo
Apex PowerFC standalone ECU
Nissan oem 740cc injectors
Walbro 255 fuel pump
Sard fuel regulator w/ gauge
Splitfire Direct Ignition Coils
Flex-a-lite fans
Koyo radiator
After drifting, I turned off the engine for cooling. After 2-3 minutes, I tried to start my car, but it couldn't start. I heard the injector noise, so I don't think I have fuel or injector problems. There was electricity. The engine didn't crank. The oil temp was about 70-80 deg C, and the water temp was about 110-117 deg C.
After resting the car for about 10 min, the oil temp was about 60-70 deg C and water temp was about 80-90 deg C. I cranked the engine 2 to 3 times in order to start the engine.
After further letting the engine rest, the engine started without issue.
So what could be the issue in the first place?
1) Simply because the engine is too hot. Apex PowerFC refuses to start the engine?
2) Apex PowerFC cranking setting?
http://yfrog.com/n1dsc00007wj
3) Battery issue?
4) Motor starter issue?
My guess is number 2 Apex PowerFC cranking setting. I had issue with starting the engine in cold weather, so I increased the injector time.
I increased the PowerFC injector time "+80 deg C" and "+50 deg C" to "+14 msec", but the engine didn't start.
So I am not sure if I should continue play with the PowerFC cranking setting.
Thanks!
