sr20det engine PLEASE HELP!!!
takae86trueno
Car: 89 240sx coupe redtop sr20det
HI im new to this website and i have a problem and i am seeking for some help!!!
I just now finished a redtop sr20det swap into my 89 240sx. I am having a problem. the engine starts up and idles normally but when i go and try to rev the engine i can only go up to 1500rpms at full throttle. And when i let off the throttle the engine stalls. I worked on it all day i checked the maf and its good. checked the timing and its good, i replaced the temp sensor and tried another ecu and all good. brand new spark plugs ngk. replace the tps sensor and same thing. checked for any leaks and no leaks at all. check fuel pressure and getting a costant 38 psi of pressure so thats good. So im all out of ideas on what to do and i still cannot figure this problem so can someone please help me out please!!!!!!!
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
It is in LIMP mode for what ever reason and normally that is a MAF issue. How did you check the MAF to see if it was good?
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
takae86trueno
well i took another maf from a good running sr20det and it did the same thing and by the way what is LIMP mode can you inform me on what that is!!
