SR20DET Engine Mods/Aftermarket parts
Jala47
Car: 1999 Nissan Altima GXE
If I were to purchase an S15 SR20DET would I have to get all of my parts for the engine or anything related need to be imported or could I locate them here?
And if i want to add Aftermarket producst to this engine would those also be required to be imported or can they be located here as well??
BTW Does anyone here know of the "Secret Services" in St. Pete, FL? http://www.secretservicesinc.com/index.html and have they used them before because i'm still debating wether going to them or going to XATRacing for my engine/fron clip
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Im pretty sure the S14 and S15 long blocks are almost exactly the same, but the clutch, transmission and rear end are all different.
S13240
J-Spec Tuner wrote:Im pretty sure the S14 and S15 long blocks are almost exactly the same, but the clutch, transmission and rear end are all different.
Remember that people in japan swap out their 6spd trannies out for s13 or s14 trannies.
BTW, nothing but good things heard about Secret Services.
Jala47
S13240 wrote:Remember that people in japan swap out their 6spd trannies out for s13 or s14 trannies.
Why would they swap out the trannies for older ones? are they not as good or do they just want 5 speeds? -sighs- I previously heard that the S15 SR's where better... so should i just get an S14 SR20DET instead? Only reason i was going for the S15 was because i read that it had more HP which it does and something about the the turbo being bigger or spooling up faster or what not but if that 30 extra HP is the only diff then i'd just go for the cheaper S14
Jala47
and couldn't I just keep the transmission from the 240SX or would i have to get a JDM one as well?
Siddhartha
Car: cars computers women martial arts
S15 has more hp stock.
Think about the 6spd this way; 6 gears in almostthe same space 5 gears were before. Basically, the 6spd is weaker, or so I've heard from people on the board.
Onizuka
Its not weaker really, its just that if you break a SR 6 speed, whats cheaper to replace it with: A $4000 new 6 speed from the dealer? or a $200 5 speed from the junkyard?
Jala47
so basically i should get the S15 engine and an S13-14 transmission... hmmm
VitaminT
Car: 93 240sx SE
I would get the S15 engine and S15 transmission. Then if it goes out sometime down the road just replace it with a S14 5 spd. The way I see it is if you are going to spend the $$$ for the S15 motor why not go ahead and get the S15 transmission. Plus most of the transmission's probably have way low miles, so there is less of chance the syncros are trashed.
Siddhartha
If it isn't weaker then why do dudes in japan trade them for 5spds?
VitaminT
Car: 93 240sx SE
I don't care if it is weaker or not. I would still want it. So be it if it breaks after a few thousand miles. You can't tell me that it is going down the drain with the car on the stock turbo. I mean I may not expect it to hold 400+whp, but it should hold what the stock turbo can do. And if not scrap it and try again with a 5spd.
I guess my point is why not? He is probably going to end up paying for it anyway.
Onizuka
Siddhartha wrote:If it isn't weaker then why do dudes in japan trade them for 5spds?
J-Spec Tuner wrote:Its not weaker really, its just that if you break a SR 6 speed, whats cheaper to replace it with: A $4000 new 6 speed from the dealer? or a $200 5 speed from the junkyard?
In all my years i have never seen one case of a 6 speed breaking or being swapped out. It is my firm belief thats all just internet rumor.
Jala47
VitaminT wrote:I don't care if it is weaker or not. I would still want it. So be it if it breaks after a few thousand miles. You can't tell me that it is going down the drain with the car on the stock turbo. I mean I may not expect it to hold 400+whp, but it should hold what the stock turbo can do. And if not scrap it and try again with a 5spd.
what don't you expect to make 400 whp? if you mean the SR20DET transmission i've seen one hit 422 on a Dyno before in person.. I wasn't to sure if it was WHP or not but it was 422 and it held it just fine
VitaminT
Car: 93 240sx SE
I just used that number as an example. I don't think anyone REALLY knows what the 6spd will hold simply due to the lack of them in high HP cars in the US. You may be able to find some info from RHD cars.
Jala47
VitaminT wrote:I just used that number as an example. I don't think anyone REALLY knows what the 6spd will hold simply due to the lack of them in high HP cars in the US. You may be able to find some info from RHD cars.
Where's RHD cars?? and anywayz wouldn't a 6spd transmission be able to withstand more than a 5 speed? essentially? or am i just off? :confused:
VitaminT
Car: 93 240sx SE
Not necessarily. The durability has nothing to do with the number of gears. I would think that due to it being design 10 years after the redtop and other trannys that it should be stronger, but the "theory" is that if you have 6 gears in the same physical space as 5 then they have to be small and therefore weaker.
Siddhartha
I stand corrected.
They belief was that they put 6 gears in the same place they put 5 gears before, so the gears were slightly narrower, but if the changed the design of the gears and the materials they are made of then the 6spd could be as strong/stronger even that the 5spd.
VitaminT
Car: 93 240sx SE
Isn't technology great.
Morph
Car: 91 Sr Powered Coupe
Jala47 why do you want to put your self through all of this headache just for 50 more hp.
Nismo_Freak
Car: 89 Nissan 240SX
Wider gearing between gears... no one wants to shift 18 times when they only have to shift 10 times with a 5-speed.
6-speeds aren't faster, they just get better gas milage and can have more top end.
Jala47
Morph wrote:Jala47 why do you want to put your self through all of this headache just for 50 more hp.
well it's like 20-30 or something but the engines also newer so i'd just figure it'd be better to get overall -shrugs- it'd be worth it in the long run my only problem now is figuring out how to get all the parts for it -shrugs- that might be a hassle
Morph
Ya its newer and has a 6speed trans but its going to be a long hard install IMHO its not worth it at all for a few minor pluses. My s13 took 3+months i cant imaging what an s15 would be.
Jala47
is 3 months normal for an engine swap like that? (S15 into a 97-98 240?)
Morph
na dude thats my expierence. and its still going:D
VitaminT
Car: 93 240sx SE
And I though that my redtop in a S13 taking 6 weeks was insane. Of course I was doing it by myself (wiring and all) and only had simple hand tools.
