Phax wrote:For emissions, a swapped SR should run as clean, if not more cleanly than a KA. Here in CA, there are a guys running around in pre-95, swapped 240s that pass the sniffer test all the time.
Phax, do you have any tips for me on how to get it to pass the sniffer in socal? I think our ppm here is 100 or something like that, and my friend in Nevada w/ his SR just BARELY got under their 220 ppm standard.
The reason I ask is that I just found out that because of where I bought my car, I will probably have to do a running dyno smog check, which sucks big fat rhinocerous ****. So I either have to swap the KA back in after the SR is ready to go, smog it, then swap it back in as quick as I can... which I'm not too keen on doing. I may have another option, but it's not concrete yet.
