SR20DET electrical problem / fuel cut
skyliner
Hello,
I'm having some problems with my car, and i realized that i posted it in the wrong section of the nico forums ... sorry about that.
heres the post zerothread?id=116325
Hopefully, i can get some ideas.
Thanks
'Nik
NISTECH
If you can not reset the codes there is a failure happening right now. You did not cut the original ground wires off the harness going to the ECM did you?? If you did your problem likly lies there as the ground for the MAF goes into the ECM. you need to splice into the original wire and run a parrellel ground with it. hook the other end of it to the intake manifold.
skyliner
thanks for the post nistech.
But yes i spliced it, and i attached it to the block where i attached a part of my grounding kit.
