sr20det electric water pump?
crazyae
Car: ae86
I have seen on the internet an electric waterpump for the sr20. It essentially makes less resistance on the engine by eliminating one of the belts. Also there is a plate that covers up where the water pump used to be. Does anyone know what i am talking about or have the link??????
thanks
240SXer
Car: 1995 240sx SE (2jz powered)
Meziere makes one for the SR20DE (FWD) They say the blockoff plate will also work for the DET. Only problem would be getting a smaller belt to work with. Also, you'd have to splice into the lower radiator hose, and i would not use that weak 21gpa pump that kit comes with. I'd but the blockoff plate and usee a 300 series 55gpa pump. That's just me though. I made a post on FA abou it:
http://forums.freshalloy.com/u...art=1
Keep me updated. You do have an SR20DET motor right?
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
I would not suggest connecting an electric water pump using either of the radiator hoses. The thermostat prevents coolent from circulating to the radiator until coolent passing over it from inside the block rises to a certain temprature. Stagnent water in the block while the car is running is not good. Eliminating the thermostat to solve this would cause incredibly long warmup times.
Anyways, all the endurance SR20 powered car used in professional racing, that I have seen, use a mechanical unit in the stock location. Just food for thought.
crazyae
Car: ae86
this whole electric what pump idea doesn;t seem so great! I think i might just keep the stock water pump. Anyways i do have an sr20det i just picked it up the other day and i plan on putting it into a corolla (ae86) coupe.
BoostFab
Car: S13cp, S13fb, S14z
how about putting the motor into the car and get it running first before all the crazy ideas....
crazyae
Car: ae86
thats not a crazy idea electric water pumps are nothing new. Also as far as the motor going into the car its not consider to be that hard because i am by passing many things.
240SXer
You wussed out. All you've gotta do is drill some holes in the themostat to allow SOME flow to occur. If you've got an electric fan the warmup time would not be that crazy. But it will take a bit.
