sr20det ecu wiring diagram
xero1
Car: 08 Altima Coupe
i need a sr20det(blacktop) ecu wiring diagram, does anyone konw where i can get one?
Silvia007
Car: 93 Nissan 240SX SE Fastback
So is this for the S13 or the S14 black top? Anyway, here's both.
S13http://home.comcast.net/~yota0...t.pdf
S14http://home.comcast.net/~yota0...s.pdf
It's not a wiring diagram but it's a pinout... if you already have it, ignore this post.
xero1
that part of what i'm looking for, but do you know where i can find a ecu wire diagram?
Silvia007
You still didn't specify which SR20DET Blacktop, S13 or S14. Here's one for the S14 Blacktop, I've only found CA18's for the S13's so far, I'll look for one with the SR.
http://home.comcast.net/~yota0...g.jpg
xero1
i have a sr20det blacktop s13
xero1
i have a sr20det blacktop s13, and i need a sr20det(blacktop) s13 ecu wiring diagram
Deadrodent
Car: 1992 240sx hatchback
+1 for that
180fan
Car: 89 fastback
it's essentially the same for the blacktop s13 (well, not the kouki s13) as the redtop, just the o2 wire is moved over.
Deadrodent
I have a 98 type X sr20det blacktop with the J4 ecu.....so it is essentially the same?
