SR20DET ECU question..
tyblue
if i have an sr20det s13 blacktop can i buy, and use an s13 redtop ecu?
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Yes I have a red rop and am using a blacktop ecu.
solidglobe
ii have 2 sr ecu if you havent found one. one 62 and one j4. 62 will be easier to upgrade compared to j4
Black Lion
Car: 1996 nissan maxima
compactfean wrote:Yes I have a red rop and am using a blacktop ecu.
what is the difference in redtop and blacktop?
tyblue
ive looked around but havent bought anything yet, how much are you wanting for it??
tyblue
just the valve cover i guess haha good point!
Black Lion
tyblue wrote:just the valve cover i guess haha good point!
and they charge you more money for that ha
DuckyD
Car: 1995 240SX
There are three types of S13 SR's.Redtop used 62/63 ECU and had a skinny-type o2 sensor on the turbo outlet.
Blacktop used an E5/E6 ECU and had a fat-type o2 sensor. Aside from the black valvecover, it also has cooling fins on the front of the head. Has 54c pistons (supposedly stronger), a better oil pickup, and a different AC compressor.
The above two SR ECU's are interchangable for the most part. Different o2 sensors can cause rich condition but isn't terribly bad.
Blacktop Type-X used a J4 ECU. Pinouts were different and J4 ECU will not work other S13 SR's unlesss repinned (and vice-versa).
solidglobe
tyblue wrote: ive looked around but havent bought anything yet, how much are you wanting for it??
$150 for either one. but the 62 will be easier to upgrade and the j4 will have better stock map mey need pin changes if using older s3 harness. about 6-7 wires
