SR20det ECU question
plainzwalker
*Sorry, just noticed that I posted this in the wrong section*
Just a quick question about the SR20det ecu (I get these random questions when I'm bored).
Does the ecu come with a speed limiter? Or is that only on the USDM ECU?
Thanks
jjisguilty
Car: Zenki S14
I believe that the speed limiter is a little harness connected to the transmition. I don't know if the SR transmission has that on there, but i'll know soon. CLIP ON THE WAY FTW!!
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
my redtop does, it sucks, i hit it all the time cause the SR gets up there to fast. its at like 120 id say maybe alittle more.
plainzwalker
I know its like the 2nd connector from the rear (or the 1st, cant remember which) on the transmission and a green/white wire going to the ecu. You cut the ecu wire and pull the transmission connector and speed limiter is removed, just didn't know if this was the case with SR20 or just the KA series.
Owell, guess I'll just install 2 switches and run some wires or something.
