Mynismo those are some very exciting figures . Well done!Cyberkreig wrote:Nice numbers but your t25 wont live long, trust me.
Same thing that kills every moving mechanical part, friction. Think about how much faster that little compressor wheel has to spin to create 15psi. i dont have hard facts honestly. Is it 30,000 rpm? 50? 100? Anytime you spin metal against metal you create heat, friction and wear. The guys at JGY customs suggested that at 15psi you have a max of 12 months life on a healthy t25.chickentendah wrote:
Cyberkreig, please explain what brings you to this conclusion of premature turbo failure. What makes the T25 die faster when you run it at 15psi (or anything from the intended 7psi)? Sorry, please enlighten me since I'm not very familiar with turbocharger science!
I get 327 ft-lbs at 4250rpm and 265whp with 11.5 a/f on stock s14 T28(16psi) so yeah you can get a bit more out of your setupmynismo wrote:
i think there's a little power that's lost down low as well as tq because its not getting enough fuel. i bet if i hooked up an afc i can squeak it up to 260-265whp with an even higher tq number.
Do you have stock exhaust? Or a stroker motor? Weird cam combo? That's some crazy torque.B.L wrote:
Yeah ... at his peak torque point he's making 264.6whp and we know SR's don't make peak HP until the 6000 mark usually.Cyberkreig wrote:those numbers seem mis-matched to you too? Hp seems low.
i've got just about the same exact mods, but you've got a maf and enthalpy over me... im jealous you actually paid $500 for a stock tuned ecu? i wont spend that much until i get a turbo upgradeNismo_Freak wrote:Awesome... makes me wonder what I'll put down using a really similar setup but with a few extras.
- Apexi Filter- SPL Exhaust Manifold- SPL 02 Housing- Z32 MAF - Enjuku Racing Intake Pipe- Blitz 3" Downpipe- 3" Test Pipe- 5Zigen Pro Racer A-Spec Exhaust (sold the Nur Spec)- Enthalpy Tuned ECU- Blitz FMIC- Enjuku 2.25" Hotpipe
Well I didn't pay the normal rate... but compare the following:mynismo wrote:thanks for the comments guys..
im turning boost down to around 12-13 psi, since it only holds 11.5 or so on topend. i want it to last at least another 6-8 months before the gt2871r goes in
i had a blitz ecu in my old car, and compared to the mines..... the mines is complete crap i dont think it does anything. all it does is raised rev limiter (7700) and speed cut. it said slight ignition timing and fuel maps but i dont feel any of it. and you would think if they did tune it for 14psi that i would be quite a bit richer from 3.5k on. i would love an enthalpy ecu but its $$$
