What is the start signal fuse? And where is it located?compactfean wrote:Maybe it just flooded out. Pull the fuel pump fuse and crank it for a bit. If it won't start because its flooded, than it should start for a little bit with fuel pump fuse unplugged and then die. Also check your start signal fuse. (if car was wired properly)
Ok, so I rotated the CAS, when I do, all injectors fire at once!!!compactfean wrote:Sounds like One of the injectors (or multiple ones) are getting grounded out BEFORE the ecu grounds them out. Id pull the fuel rail and put some paper towels under it and check the spray pattern. You can pull the cas and mark it before you spin it. Spinning it should fire each injector individually. (be careful, unplug the coils and stay away from any ignition source).
Just put in another ecu, same thing. I'm going to check out the harness some more, but it is brand new, not like a 15 year old JDM factory harnesscompactfean wrote:Ecu fried or a section of your engine harness is damaged. If all the injectors signal wires are touching causing them to fire at once you would have continuity from one injector to another. If the signal wires are shorted to ground somehow the signal wires from the injectors would have continuity from signal wire to chassis ground with the ecu disconnected.
No I haven't because I've been unplugging sensors, and messing with them, and swapping ecus and stuff.compactfean wrote:Yeah id do some further testing and narrow it down as much as you can. Have you pulled codes?
Only runs for a couple seconds at a time when I pull the fuse. won't even pop with the fuse plugged in. Do you know if this motor runs with a waste spark?compactfean wrote:^true, only thing I can think of would be if the cas is messing up but I wouldn't think that would be the case since the ign firing is still working (when you pull fuel pump fuse it runs...... Proper spark)
Awesome, thanks for the info!!!blkvrtswp wrote:I have read that during startup for around 4 seconds all 4 injectors will batch fire at the same time.
So I tried everything you said, still the same thing? Will only start with the fuel pump fuse unplugged, and even then for only about 6 seconds, if you plug the fuse in during this time it will instantly die. Also, I need to hold the throttle wide open for it to idle for those 6 secondsblkvrtswp wrote:CAS signal to the ECU indicates engine rotation. For example, the fuel pump will shut off after 3-4 seconds if the ECU does not see the CAS signal indicating engine rotation.
If the CAS alignment is off a little it will be even harder to start if it is just a little too wet in the cylinders.
I would pull the CAS, pull the plugs, dry the cylinders with a hair dryer, plugs back in, install CAS making sure it is 100% perfect (it is easy to get this wrong), give her a shot. Good luck!
Ok, I can do that, I basically aligned the first timing mark (the far left when looking at the front of the motor) on the crankshaft, when piston #1 is at tdc on the power stroke. Then the hash mark on the cas to the dot on the shaft of the cas.blkvrtswp wrote:Post pictures of your CAS install & alignment so we can verify it is correct.
