Sr20det driving problem
nismo silvia
Car: 91 240sx Coup, 92 240sx Vert
I just rebuilt my sr I ported and polished my head and have crower titanium springs and retainers. I have an tuned ecu and a stock one the tuned is setup for 550s and a 2871r. With both ecu's a code 55 is thrown which my friend says is the all clear code but looking at the code book it looks like it is another code use dia-port. But my friends car throws the 55 code and runs fine. My car idles fine at +- 800rpm and is the second mark from the right on the base timing. When I try to drive the car the motor hesitates and does not want to go kind of feels like the same problem I had with my KADE when i blew my brake booster line, I checked for vaccume leaks and found none. Also my wideband reads 14.8 at idle if anyone has an idea let me know thanks.
Justin35ll
Car: s13 coupe sr20det
code 55 is normal. Not sure what your problem is.
nismo silvia
Ya it is very weird this is like my last hope lol
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Um... It's suppose to be 2nd mark from the left..
nismo silvia
I thought the second mark from the left was to stab the cas and the second mark from the right was where you wanted your base timing at??
PyR0NiAk
You're right.. My bad. According to Nissan, code 55 requires a consult cable. My theory on it is that since most people wouldn't check for codes unless something is wrong, it throws a 55 when no other codes are being thrown...
nismo silvia
So Im ok then with my timing
CRyan
Car: 1997 Nissan 240SX
yeah your timing is fine for a close to stock setting elsewhere.
Getting a code 55 has only ruled out that it is nothing within the ECU, so you may be looking at something mechanical. First step I would take is drive the car and get a reading on your lambda to see what it does throughout the RPM band.
nismo silvia
It ritchens up arround 12 11 when i try to drive it and hesitates so bad I dont want to take it up past 3k is what ive gone to kind of feels like no power at all but it starts to build boost soI dont think it would be my turbo.
PyR0NiAk
Sounds like a post maf leak of some sort... Z1 Motorsports sells a boost leak tester...
nismo silvia
Ya i thought it was either a bad maf so i switched it out with another one and I had the same problem so I went to the parts store and got some starting fluid and sprayed arround all of my couplers manifold and s*** and the idle didnt increase. But I guess i will test everything again and see where im at
