sr20det dipstick pops out
lazyeyes13
Car: 1991 s13 hatch rb25det
1989 s13 hatch
2004 g35 coupe
The dipstick keeps popping out on a blacktop sr20 when I really get on it. Ive searched and read similar threads saying it could be a bad oring on the dipstick or it could be blowing out due to high crankcase pressures. It builds boost and pulls hard just fine so I'm hoping its just the oring on the dipstick. How can I know for sure??
2_Liter_Turbo
Car: _________________
'96 S14 Coupe: SR20VET
'90 R32 TH1 GTR: RB26DETT
'92 S13 Fastback: SR20DET
'11 V36 Sedan: VQ25HR
'06 GMT800 2500HD: LBZ Duramax
Can you explain how your pcv system is laid out? Is it facotry? Does it have breather filters, are things capped off? Regardless if the O ring is bad or not, you are experiencing crank case pressure. It could be a lot (good O ring) or only a little (bad O ring). Doing a compression check and knowing your pcv setup will help a lot in determining which scenario you fall into.
lazyeyes13
1989 s13 hatch
2004 g35 coupe
This isn't my car, Im looking to trade my current 240 for this one but this has been sketching me out a little bit. Im assuming its the stock pcv setup and I'm gonna compression test it as well. Worst case scenario would be fried rings correct? And what are good compression numbers for blacktop sr?
2_Liter_Turbo
157psi is factory spec. If it's below 145psi or has a larger than 14psi spread, then walk away. I may be off a couple psi or so, but I think those are the exact numbers.
lazyeyes13
1989 s13 hatch
2004 g35 coupe
Okay, thanks. Appreciate the info
