Sr20Det dies
weekilty
Car: Cars, X-Box and my Family
The motor runs, pulls, idles and Spools up fine.My Problem is:once the car gets to operating temperature and I come down the gears to a stop the car wants to die.If I catch it quick enough I can stop it from cutting out or with clutch control i can keep it runningAnyone have any ideas??How about the screw on my intake manifold?Could timing be off a littleit idles at 900rpm the rest of the time.
float_6969
Have you checked for boost leaks? Do you have an atmospheric BOV?
PalmerWMD
Car: 2004 350Z
I have the exact same problem.
Its the fault of my atmospheric BOV.kinda acts like a vaccum leak in symptoms.
Fred...:)
NeedCAforS13
Car: CA swapped S13 coupe
I would point towards the bov as well... or boost leaks somewhere in your piping.
try disconnecting the vaccum line to the bov (and of course plugging up that line) to prevent the bov from opening and go drive it like that. if it still gives you problems try spraying carb cleaner on all your hose connections and intercooler piping to check for leaks. if there are any holes or leaks, the motor's idle will shoot up momentarily due to the carb cleaner:)
Sean
float_6969
:withstup
nlzmo400r
Car: '02 Nissan Altima QR25DE
'93 Nissan 240SX hatch KA24DE
i had a vacuum line leak on my intake and it did the same thing, so im sure thats your problem, it bobbles between 8oo-1oo rpm and then dies if u let it?
