kingtal0n »
https://forums.nicoclub.com/kingtal0n-u29036.html
Wed Jun 29, 2011 5:57 am
For the rpm to stick like that, extra air has to be flowing into the engine. If the throttle body is closed, air cannot enter that way, so it must be entering through your IACV motor. If you block the IACV tube off (clamp the rubber hose with a vice grip) the problem should dissipate (to confirm diagnosis)
At which point, you need to figure out why. most likely the computer feels that the 2,000rpm hang is necessary, or the IACV is bad/worn/dirty.
If it turns out to be related to the computer, it may have to do with input from a sensor (tps/maf/coolant/knock/etc) or something in the computer. I noticed the engine seems to dip very low in RPM and idle rough, this is an indication that either you have some aftermarket cams (hopefully) or the maf/computer is reading incorrectly, perhaps there is a vacuum leak or a stick value in a sensor.
Start out by figuring out if you have the right computer first. If its an OEM redtop, it should be a #62. If you have a #63 for instance, that is automatic transmission, and the engine may hang like that due to deceleration expectancy from the VSS or something weird like that.
