2_Liter_Turbo »
https://forums.nicoclub.com/2-liter-turbo-u12924.html
Thu Jan 29, 2015 9:12 am
Well it's either fuel or spark, so if the fuel is good then I'd look into your coilpacks and even your ignitor chip if the coils check out. And if they wont work past that gap, then I'm thinking you definitely have some spark issues (unless you run a ton of boost on a decently sized turbo, ha ha). What plugs are you running? Do you have access to an extra set of coilpacks? If you're on stock coils, then maybe just upgrade. I know when I went to splitfires, the car ran 100x better.
