SR20DET Crankshaft help
240sxinlv
Don't know if its my crappy computer or adobe but I can NOT open the S15 SR20DET FSM.
For an FSM, go here:http://www.zeroyon.com/index/content/view/24/47/
I need the following specs if someone can get them for me.
If there is an "Engine Mechanical" ("EM") section....
Crank Shaft - Main Jounal Dia. (DM) - ???Pin Jounal Dia (DP) - ???Center Distance ® - ???Taper of journal and pin - ???Out of round journal and pin - ???Runout - ???Free end play - ???Fillet roll - ???
Main Bearing Clearance - ???Connecting rod bearing clearance - ???
Available Main Bearings -Grade Numbers, Sizes, Colors ???
Available Connecting Rod Bearings -Grade Numbers, Sizes, Colors ???
Thank you
SpeedRacer1
Car: 1990 240SX, G35
