tiger »
https://forums.nicoclub.com/tiger-u28425.html
Wed May 09, 2007 6:44 am
I believe you're supposed to put it on both sides of the bearings.. (correct me if i'm wrong.. ) It shouldn't be binding up unless the bearings are the wrong size.. that may be the problem. Also you're supposed to select bearings according to the number stamped on the crankshaft unless you had your crank shaved then you would add and get oversized bearings.
