mynismo »
https://forums.nicoclub.com/mynismo-u6813.html
Wed Sep 08, 2004 12:15 pm
i have a problem with my s13 redtop cooling (im sure im the millionth person by now).
i have a koyo aluminum radiator with 220 twin flex-a-lites, wired to a painless performance thermostat fan relay drilled into the radiator right next to the lower radiator hose which is supposed to come on at 200F and off at 185F. my water temp gauge is a techtom cmx-100 which reads off the stock sensor, which i know is reading the correct temp.
it was running PERFECT after i flushed the cooling system with derex flush fluid. as read by the techtom, the fans would come on at 195F and off at 180F. it was running just fine and dandy for two weeks.
i had to get rid of the derex fluid and the fact that it was all water, so i drained it out, flushed it with water and filled it up with 50/50 and water wetter using the correct bleeding procedure for this motor. temp goes up to 177F, which i believe is when the thermostat opens, stays there for a little bit, then starts to move upwards slowly. im keeping heater on H on level 4 to let the heat out. if i let it idle with heater on full blast it goes to 195F and stays there (for a good 1.5 hours) with radiator cap on or off. if i turn the heater off, the temp slowly rises and keeps going up (the fans don't come on). turn it back on, temp slowly goes back down to 195F.
the problem is that the fans just aren't coming on at idle. they were coming on before at 195F and it was all perfect until i had to change it to 50/50. during driving, the fans come on erraticly at different temps, inbetween 195F and 220F. if i idle they don't come on.
any clues? im losing my mind. i bled the system a good 10 times and this has taken up the last two full 8 hour days and its just not running like it was two days ago. im tempted to change the location of the thermostat for the fan into the upper radiator hose because for some reason the temperature before the car thermostat in the bottom radiator hose is not going up to 200F. the thermostat is brand new and has been working before just fine, and the car is not overheating with radiator cap off and heater on full blast. if it was a bad thermostat the temp would just completely rise and wouldn't stop.
what are your thermostat controlled fan setups? where do you put the thermostat for your fans? lower radiator hose? i would really like to know because i've just about had enough.
what i don't get... is that it was running PERFECT with the derex in there. i might just put it back in and call it a day.
Modified by mynismo at 6:30 PM 9/8/2004
