Postby
jeff13 »
https://forums.nicoclub.com/jeff13-u15413.htmlSun Mar 26, 2006 7:53 pm
hey guys,I have a blacktop S13 SR20DET and I need to replace my coolant temp sensor for the ECU, not the gauge, and need the part number. I did a search on it and end up with the same name for both sensors (gauge and ECU). Thanks for your help in advance.
Postby
180fan »
https://forums.nicoclub.com/180fan-u3602.htmlSun Jun 04, 2006 11:55 pm
follow your lower radiator hose. you'll see an elbow pipe go to your block. on that you'll see two sensors behind the elbow. the one with 2 wires is the CTS.
