sr20det consult wiring..
icemhan_21
Car: 1996 240sx
my registration expires this january and my sr swapped 240sx cant pass emsissions because i cant get the consult to work. i dont have any problem with the breather because my car is 96 obd2 so i dont need to take it i just need a catalytic converter which i have and just need to pass the diagnostic test which i cant pass because my consult isnt wired up.. i cant find any info online on how to wire it up. this is my only car so if i cant get it registered before this month ends im dead.. if you could help me please pm me..
dm-ka
Car: z32tt-sold, '95 S14-sold, '97 S14-sold, another '95 S14-sold.
Current car: Q45
If I'm not mistaken you will not be able to pass emissions with SR swap because even if you somehow manage to wire your consult up our US diagnostic equpment won't be able to comunicate with SR ECU; or something like that.Somebody correct me if I'm wrong.
SpeedRacer1
Car: 1990 240SX, G35
Thats right, consult and OBD II are two different things. The Consult port allows Nissan to read problems with the ECU. The Nissan consult system can read problems, even from the JDM ECU. The OBDII system was mandated and agreed upon by car manufacturers in the US. So OBDII is found nowhere else in the world. On board diagnostics II communicates with USDM ECU's and figures out if there are any errors or anything else going on with the car that might stop it from running correctly.
I dont know the law in Tennessee but back when I lived in Washington if you brought in an OBDII car and for whatever reason they couldnt scan the ECU they would just do an exhaust emissions test instead. See if thats an option because OBDII on a JDM engine isn't an option.
dm-ka
Current car: Q45
Here is another idea for you find nearby county where emissions are not requred and get a P.O. Box in that county and register your car in that county. That's what kids do here in STL.
