compression wrote:I guess I can add some stuff.
I guess the S15 engine has a higher compression ratio because they want it to feel strong even when it is not in the boost. They probably have a conservative timing map in it and add a little extra fuel to richen it up to keep her from knocking.
I'm just curious here. So higher octane gas is less volitile? Couldn't I just use diesle or kerosine since they're less likely to burn?
This is a theoretical question. Not anything intended to start an argument.
Also, I'm a fueler at the charlotte douglass international airport (Some of you may remember my story about drifting the fuel truck with 3000 gallons of jet fuel in the cargo tank)...... ANYWAYS, we also fuel planes with AVGAS which is (from what I'm told by the fuel quality control guy) nothing other than 120 octane gas with blue dye in it. The only thing is, I've seen this stuff spilled before and it evaporates QUICK, leading me to believe that this stuff is rather volitle and therefore, prone to quick ignition.
Does any of this make sense?
