bvanev »
https://forums.nicoclub.com/bvanev-u8898.html
Wed Aug 27, 2003 12:03 pm
This is really great information. After seeing the flywheel and clutchplate in my SR, I would suspect some really hard driving and will probably need to replace my transmission eventually anyway. Plus if I remember correctly, and it has been a while since I punched the numbers, the gear ratios in the KA24DE are a little closer(?) in the low gears and wider in the high gears, allowing a higher top speed, and better low-end torque.
