sr20det common leaks
nice_try
Car: '90 240sx with a bone stock sr20 swap!
yep. my sr is complete and runs like a new car..with boost! my favorite part. but its got an oil leak i can't find any streams but its drippin by the very bottom center bolt on the transmission..anyone know some common places for it to leak?? i'm prayin not the turbo..but i'll do anything to fix it.
david200095367
Car: 91 fastback 93 coupe w/s14 sr20det 98 s14 kouki
i have the exact same area leak. Its either the rear main seal or i noticed my valve cover gasket it leaking and it might be dripping down the transmission.
fast_s13
is it motor oil or gear oil...the rear seals in tranys always leak
david200095367
mine is motor oil.
jr_ss
Car: 95' S14
I have that same symptom... I can't figure it out. I think the oil is actually coming from the trans fill bolt on the side, but I've tried everything to get it to seal and still nothing..
nice_try
well i can't find anything! i can't tell if its motor or gear oil..it does look like its comin from the transmission..i need a solution or confirmation that its not going to damage it. i don't think it should cause its small and not noticible. i might go crazy with this car but i'll never get rid of it!
Hijacker
Car: '92 240sx Convertible
'94 F-150
I have a feeling you're probably leaking through the drain plug. My advice would be to pull the drain plug, and subsequently the fluid, and replace the plug with either teflon tape (yellow kind. the white kind will dissolve in oil) or silicon sealant on the plug threads. Sometimes, fluid leaks past the fill and drain plug threads and you have to add a little something to them to keep them from leaking.
And since it's a trans leak, I would be more pro-active about fixing it. It's a PITA to check the fluid level, and you'll be sorry if it gets too low and you don't notice.
goalguy02
Car: '92 240
If you have motor oil on your transmission it could be a couple things depending on where the oil is found. If the oil is dripping down the transmission from the top, it is most likely a valve cover gasket leaking. If the oil is showing where the transmission and motor meet, then it is most likely the rear main seal on the motor. Best way to find it is clean off all the old oil that has leaked out and check underneath every couple of days. If its a slow leak it doesn't need immediate attention, just keep up you fluid levels. If you clean it off and the next day you have spots on the driveway, better to fix it now.
nice_try
well i was studyin the leak and it looks like a pretty bad leak from the top center of the transmission..its wet from there and down on the frame in a pretty wide stream..i'm gonna seal the plugs with that yellow teflon...hopefully that works i'll get back to you after that. any other suggestions??
Hijacker
'94 F-150
Check the reverse gear sensor for leaking. A lot of times when they get old, the internal seal starts to leak and you can't stop it. I've had it happen. I would also consider checking the other sensors as well.
