SR20DET clutch problems
Garageguy8725
Sr20det with sr20 trans. 6 puck clutch only master cylinder and slave no damper box or any other bs. My problem is I cant get the car into gear when i press down the clutch. I see the slave moving and bleed it every way possible. Has anybody ever encountered this problem or maybe have any solutions to this. thank you.
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
It won't stay in gear once you out it in gear? Sounds like a trans bearing issue.
