Its not what you know, its what you can prove. So can a SR20DET reach 275HP? Were about to find out.
SR20DET Specs: (Usually)
206HP
205ft-lbs
(At 7psi)
Everywhere i have read, from magazines to forums. It says that each psi gives you at least 8HP.
Safe limit you can take the stock turbo is between 10-12psi. Yes you can take it to 13psi but ie read that you will hurt your turbo
and really doesnt do much for you. That just on everything i have researched. Let me know if im wrong. (Safe Limit 10-12psi)
So if you can push your SR20DET to at least 12psi (Lets do some math
Lets say we have a Brand Name Cold Air Intake (CAI), full exhaust, and high end spark plugs. Ok lets call on some names.
K&N COld Air Intake (CAI) will give you a minimum of 12HP. Might be more or less, thats just an average. 246HP+12HP=258HP
A Full Exhaust System (A Good One) will gvie you a minimum of 15HP. (Just an Average). So, 258HP+15HP=273HP
Now finally, 4 E3 Spark Plugs, which were proven (Videos Everywhere) that each will at least give you 1HP each. 273HP+4HP=277HP
So we end up with a final number of 277HP
