SR20det Camshaft install help...
deathBooster
Car: 240sx under construction
Need some info about Camshaft Braket bolt lightening procedure and torque spec...
Found this link for Black top S14. will these instructions work for redtop sr20det?????
http://www.nicoclub.com/articles.php?id=224734
any comment will help.. thanks...
Slipstream
Car: '94 Sonoma, '90 300zx n/a
Those are the steps I was using for my s13 blacktop.
mrzabala
Car: 93 Nissan 240SX SE Hatch
Yes, the procedures and torque specs is the same on both generation SRs, even though there are still different things about it (which no one likes to agree with).
Modified by mrzabala at 9:14 PM 6/13/2007
deathBooster
thanks guys...
mrzabala
Just make sure to follow the steps in installing the bolts on the cam brackets. If possible check for clearance.
