sr20det cams upgrade
frosted flakes
i know im not an sr guy but mike wants me to help him choose some cams for his sr20. hes thinking hks step 2 cams 272. is there an installation guide or torque specs for this? any one have any info on the subject matter?
SpeedFreak
As far as putting them in. Its just like putting in the stock ones. But a cam that large is going to need better valve springs then the stock ones. From what I understand you can get away with 264's with the stock springs but go any higher and you are asking for problems. Good luck.
powerls
HKS offers 3 stages of cams all featuring a 264 duration. The stages offer different amounts of lift. Stage 1 can be used with stock VT. Stage 2 needs upgraded springs. And stage 3 springs and a lash killer kit
tubakins
Car: 89 240sx fastback
ur sr wont even idle with those 272 unless u got sum serious fuel tunning done. stick with the stage 1 264 unless u get new springs
Nismo_Freak
Car: 89 Nissan 240SX
How can anyone honestly comment with a semi-correct answer without knowing his setup?
need2drift
Car: 89 s13 sr20det powered coupe
Nismo_Freak wrote:How can anyone honestly comment with a semi-correct answer without knowing his setup?
you know guestamates
Nismo_Freak
need2drift wrote: you know guestamates
Ah ok.
Put a set of 280 deg. 14mm lift cams on there and take video of it so we all know what lifter death sound like
s13sr20chris
Nismo_Freak wrote:
Ah ok.
shoot why stop there? the v8's run lots more than that. we all know that anything a v8 can do an sr can do better!
Nismo_Freak
s13sr20chris wrote:shoot why stop there? the v8's run lots more than that. we all know that anything a v8 can do an sr can do better!
Right, he should run cams so tall that they destroy the oiler tubes haha.
s13sr20chris
phhhht!what do those things do anyway? ok, i will try to stop fooling around now.
