Different "stages" are only marketing gimmicks. Timing and lift aren't going to be the same between two different manufacturers.
I just did a little searching and wound up on this page:
http://www.nissansilvia.com/fo...28815
I hadn't considered adjustable cam sprockets to be used to compensate for variations in cam timing just from using a non-OEM head gasket. goes to show you how much an engine is like a precision watch. In other words you really have to know what you're doing to even make a good decision on what product to buy when replacing critical engine components, because really there's not even a standard as to how manufacturers are supposed to advertise their grinds. To figure out who makes "the best" 264, you have to decipher any technical specs available and understand what impact they'll have on the motor.
Boro, what's wrong with a re-grind?
edit: the headgasket didn't determine his cam timing, i read too fast.. according to that thread the BC intake cams are apparently all made about 11° retarded, probably not on purpose, necessitating the adjustable sprockets to get them in spec. the comment about a head gasket you'll see is a member mentioning another customer used a thicker apexi head gasket which advanced cam timing to ~8° btdc, only 3° less retarded.
Modified by Neil at 6:47 PM 9/13/2008
