Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Wed Mar 12, 2008 4:15 am
Hmm...Well, I would pull the oiler and try to blow some air through it. If they're clogged, it will be tough to blow air. Also, when you pull the oiler, double check the cam journals for wear as well. Just to make sure it's not an underlying pressure related problem to that side of the motor.
To unclog the oiler, I usually try to dunk it in a chemical cleaner like Cold Carb. You can also take some spray on carb cleaner and spray it down in the oiler. Just shield your eyes so you don't have splash back kill your vision. After you clean it out, run some tap water into the banjo fitting and see if you get an even flow out of all the holes. Once you're satisfied, dry it out and reinstall.
