SR20det build up Q's?? First timer
bleach8484
Hey guys, im new to the Board, first post.
I'll start of telling yall what i got, 95 SE with an SR20det redtop.And im already looking to start buying parts for a build up. Ive built several honda motors and currently have a Turbo integra also. So i have ideas of how to match parts.
But im open to opinions and advice, i would like 400hp area.
Thinking of HKS cams -both 264 or 264 and 272?HKS RASHKS cam gearsGreddy intake man.Full-Race manifoldTial 40mm wastegatePrecision SC61750cc injectors and a matching Tomei ECU tuned for a similar setup.other fuel enhancments, pump, rail etcUndecided BOV
And im unsure of intercooler size. Im looking at a 28x10x3, but i like the 32x12x3, may be overkill. Lemme know what you guys think about this setup. Im open to ALL advice.
Also, i would like to know where i can find a service manual for the SR20det, with torque specs and whatnot. (i like doing my own work)
Thanks guys, hope to get lots of good info off the board!
navysnail
how about beefing up the valve train, that is an inherently weak spot. there is a tread on it farther down
you should go to the dam cookout. the 240 guys on nico are geting together up there, im sure a few sr powered 240s will show up. mine is stock, i just speak from what i have read
bleach8484
when, and where is it? i would like to go and talk about Nissans, kinda get a little info on these things
navysnail
sticky on top of general chat, called "atl 240sx owners check in", its huge. i think its on the 10th page now
