sr20det build question (tunning)
lbkidsr20
Car: 240sx
i got a 89 240sx with a redtop sr walbro 255 fmic and boost controller i plan on getting the following
greddy intake manifoldinjectors (not sure what size yet )fprhks step 2 cams 264/272 or 272/272 cam gearsvalvespringsretainers rasfull race turbo manifoldgt30r
my question is whats a good size injector for this set up and how should i go about with tuning the ecu ive looked into jwt not sure how good there tunes are
Neil
Car: shooting laser guns
With respect, you probably shouldn't be thinking about this turbo if your plan is to use a mail order rom tune.
A gt30r is meant for some pretty serious power, which means you should automatically be thinking about standalone fuel management, which requires access to a dyno and someone who will properly tune the setup, cams and all. A basic mail order rom tune doesn't do much more than get your stock ECU to work with different injectors or a different maf as if they were the original equipment. Even though it'd be running, it'd basically still be on the stock tune (or close enough to it), which is fine for small turbo upgrades and ~300hp but not fine for a GT30R.
If you really feel 500hp is a realistic goal for you, then you should be seriously considering machine work and new pistons, too. If maybe you start to have second thoughts then at least know there are plenty of other better matched turbo setups out there for a street driven SR.
lbkidsr20
Car: 240sx
well i was looking more towards 400 hp but not maxing out the 30r but having the power there for the future .... what standalones are normally used with sr20? i dont have the money for a 1600 aem
lbkidsr20
Car: 240sx
Neil
so you don't want to max out the turbo but in the future you do?
All standalone is expensive. Do some more research before you get in over your head.
Modified by Neil at 8:19 AM 2/18/2009
lbkidsr20
Car: 240sx
thats what im doing research im trying to find out about tuning the car on a forum ...... so instead of telling me to search bc you dont kno the answer to the question yourself dont post at all just to get your post count up ... and if you kno the answer you could have just posted it and left it alone but no your a ****
BEST1TUNING.COM
e-mail or call me I would be happy to answer any of your tuning questions.
240_SeX
Car: 1992 240SX SE
Ive seen this too many times befor...
You will get NOWHERE on this fourm if you disrespect people.
If you have questions, great. but i would not suggest starting a thread until you have completely exhausted the search button.
Look into all the build threads on here and see what other people are using for similar setups and make a decision from there.
Tunning is the most important aspect of a high horsepower car w/o i all that money you spend is for nothing when you throw a rod or melt a piston.
gordonliu
Car: 92 s13 coupe
lulz, the irony is horrific.
I will answer the question first, because I pity you. However you are posting like an immature idiot. Sorry to be blunt, but it is true. That is why you have already gotten 2 (and now 3) negative responses.
1) you cant afford 400 hp. sorry. it is going to cost WAY more than $1600 MORE than what you have listed there to even "finish" the upgrades. you are missing some vital components
2) yes you need standalone
3) the cheapest standalone is the Power FC, which will run at least $1000 (possibly ~900)
4) abbreviated list of stuff you "still need"
external wastegateStandaloneMAF or MAP sensor02 sensor (needed)A/F meter
expect about 2500 for those parts.
on this forum, "research" means EXACTLY 1 thing: searching for and reading current/old/archived posts.
you would have answered your question about 20 times, in ridiculous detail, if you had ACTUALLY searched a reasonable amount.
Why do you think you have gotten 2, and now 3 negative responses?
because you have started a CLASSIC, annoying, "n00b" thread.
rc1honda
Car: 1992 240 sx
2007 BMW 335xi
2008 Honda CBR1000RR
No dont get a stand alone. You can use a SAFC for Apex-i. Thats all you need 35 psi of boost and SAFC you will get great knocking results!!! And why the hell is everyone callin tuning "tunning"? "Tunning" is not a word people.
two40splease
Stand alone ECU is nice, but you could just as easily get into Nistune or calumsult costs way less. I run nistune realtime tuning .
lbkidsr20
Car: 240sx
BEST1TUNING.COM wrote:e-mail or call me I would be happy to answer any of your tuning questions.
emailed
lbkidsr20
Car: 240sx
two40splease wrote:Stand alone ECU is nice, but you could just as easily get into Nistune or calumsult costs way less. I run nistune realtime tuning .
what set up you have ?
lbkidsr20
Car: 240sx
rc1honda wrote:No dont get a stand alone. You can use a SAFC for Apex-i. Thats all you need 35 psi of boost and SAFC you will get great knocking results!!! And why the hell is everyone callin tuning "tunning"? "Tunning" is not a word people.
i was looking at those but they have like 4 different versions and no description on there website about them individually
BEST1TUNING.COM
actually...i think he was joking^
two40splease
Gt2871r on 20#'sJim wolf s3'sP&P head w/5 angle valve jobP&P Intake manifoldMSD 72# injectorsz32 MAFblitz nur spec 3" inch exhaust list goes on thats the gist of it...
